any pros out there engraving polished stones? I’m engraving polished agate and my vision was that it would leave the color of unpolished stone… instead it is white?? I was hoping for the image to be subtle. I’m a total laser newbie, so any feedback is appreciated if this is possible.
I’ve never engraved it myself, but I did purchase one from one of the other members here, and the white appears to be normal for that kind of engraving:
Also, apparently you need to watch the striations in the rock - they will fracture differently.
yes that is what I’m finding. this is just what laser engraving does on polished stone I just don’t understand why the white color is what is frustrating… even with researching the subject. you would (logically) think the laser etches away the polish leaving the natural unpolished color of the stone.
In my experience agate always gets bleached white when the laser hits it. This happens at fairly low power levels, far below what would be needed to actually etch away at the surface. Some of this may be due to the dyes being bleached. (Most agate that isn’t brown has gotten its color from dyes.) But it happens on undyed agate as well, so @Tom_A’s idea about micro fracturing might be right.
You’ll need to experiment with other types of stones if you want one that doesn’t turn white.
I believe so as well. If you brush at them they can flake off.
If the white is caused by fracturing, wetting the stone might change the appearance temporarily back to the color it was. If it’s bleached, it will stay white.
The good news is, if it’s not bleached, you might be able to use something like clear nail polish on it to change the appearance again.
What is the unpolished color? In my (limited) experience it’s just a lightened version of the polished color, because the rough surface reflects differently. I bet if you engraved some kind of speckle pattern you might get close…
It would be due to the micro-fractures - same as if you chip away at it… (Glass doesn’t stay clear when lasered and slate doesn’t stay black…) (That’s my guess and I’m stickin’ to it…)
This is true. I tried various different ways… and I think this is just gonna be white! I’ve been able to dull it, though… using low power then brushing with a wire brush.
I wonder if a thin ink like an alcohol based such as from Copic pens could flow into the cracks and provide some pigmentation yet easily wipe away from the finished surfaces.
That’s a good idea. Before I give up I’m going to go to hobby lobby and see what I can dredge up. When the fragments are wet it’s exaclty what I’m looking for. So just need something to set in those fragments… you are right. TY
