Hello I am new with the GF and was wondering if anyone has engraved on a cutting board and filed with epoxy resin? I normally use a cnc router but was wanting to start using epoxy in my laser project’s. Was wondering what is the thinnest I engrave into the wood for the epoxy and what type of sealer to use in laser engraving before adding the epoxy.
Thanks!
Hey, welcome!
There have been quite a few posts about inlaying with epoxy:
https://community.glowforge.com/search?q=epoxy%20inlay%20in:first%20order:latest
The de facto champions of the form are probably the maniacs over at @Whengeekscraft, you should check out their map projects, or especially their D&D book covers, crazy good work combining laser cutting and epoxy infills.
And for more from them:
https://community.glowforge.com/search?q=@whengeekscraft%20in:first%20%23glowforge-project-examples%20order:latest
Thanks will check it out!
Have fun with your GF; I hope you post photos of what you do. Even the “mistakes” can be valuable. (You’ll see plenty of ours on this forum!)
