For the last couple of days when I try to upload to the app I am getting an “Aw, Snap!” error or it just times out. I’ve cleared caches, I have memory and I also tried on my phone (pixel6 pro), same results.
Help please
TIA
Help please
TIA
Do you mean when you try to open the app from your browser?
The app seems to be alright until I try to upload. It hangs for a while and then that’s where it falls apart.
Open app - go
select create - go
select upload - full stop
Instead of uploading your file, try dragging it onto the interface.
It uploaded and then timed out. But, it did upload.
I think the file is the problem. Can you open an existing file from the Dashboard?
I can see my old files and they load into the app. But if I try to upload any new file it times out. I tried different files, formats, all the same result.
Update - The file is under 145k, and when the app crashes loading the file, after I reset, that file is then my new number 1 file. It times out as well if I try to use it. Same thing happens no what the file format is.
