hi! I hit a snag. I want to engrave a brick wall pattern. I created it in Illustrator by creating a long L shape, then duplicating it a million times to get the brick wall pattern. I export a STL and upload to glowforge. It didn’t work. Then I took all the brick pieces and did a UNITE on them thinking that it would reduce the number of objects to 1. I still get an error.
Any ideas on how to tame that image into something that the glowforge can deal with? Thanks!
If you’re engraving, it’s almost always easier/better to rasterize in Illustrator and then drop into GFUI.
You avoid weird vector happenings or overly complicated vectors struggling to load.
The challenge with a pattern like this, is most of the shape tools, like UNITE, are intended to operating on shapes, where this pattern is really a whole bunch of paths (unclosed?).
The job will process faster if you rasterize the engraving layer as well. Glowforge’s raster planner is faster than the vector planner, which has to rasterize your design to engrave it anyway.
Super helpful stuff here. Thanks! But I am still confused. I selected all the bricks and rasterized them. It still doesn’t work. Here is my illustrator file. bricks.zip (637.4 KB)
You might want to post in the Everything Else forum section. This section is intended for community help with the machine or GF UI, and many members have it blocked.
