Has there been a firmware update that altered the exhaust fan? I recently noticed that it is much quieter during a job. There is no more “winding up” when a job starts. The area seems to still get exhausted, but that may be to the vent connecting to an external vacuum system.
After extracting the logs from your Glowforge, I noticed that it’s been a while since the fan’s been cleaned. That may be the next step you should take. Go to this URL: https://app.glowforge.com/maintenance/fan
Once you’ve cleaned your fan, could you do a test print? Let us know if the noise-level is back to the normal level.
Has the volume of your fan returned to normal? If not, can you check what @primal_healer mentioned? If the “Glowforge air filter attached” switch is on, that will slow the exhaust fan down to allow the Air Filter to exhaust your Glowforge better.
Thanks for all the great tips and information. Unfortunately, I’m currently at home and working from home and don’t have any idea when I will be back on-site at work where the glowforge is located. It may be a while until I can test this out.
