For the past two days I have been stuck on the “Calculating Precision Movement” part of the print job. I have reset the machine to factory, reset my wireless, and still after about 15 minutes, I get a STOP print failed error. I’ve got 105Mbps down and 12mbps up, so internet is not an issue. The design is not complicated 56 mini chessboards with engraving on one side. If I do one, it works, but if I try to use the entire sheet, it errors out.
I submitted a support ticket, but “heavier than usual volume” like always.
Everything is using standard medium draft board settings. 1000/full/270 on a full 12x19 sheet
If I build it out with a single board it works, but if I duplicate it more than twice it times out.
Your artwork has about a bajillion nodes in it. That makes it REALLY complex, even though it looks like it should be simple. Stack 60 copies of this in one file and the GFUI is pretty certain to choke.
Ok. Wanted to make sure you weren’t using a really high LPI - and thanks for including the file. My initial thoughts were maybe that you were: 1) using a very high LPI, and while the machine can handle much longer engraves now, it still has a limit. That doesn’t seem to be the case. Or, 2) That you had a job broken up where it was basically doing an entire bed pass for one engrave, then having to go back and do another pass for another part of the job - which would (ultimately) be the same issue as number 1.
Does Inkscape have some kind of path simplify? In Illustrator, I can use the simplify command and it reduces the cutting board text from 1763 to 388 points, at 100% precision - so it has a ton of redundant points.
Also, just because you posted it and I noticed it, you have some stray points around the cutting board text that are going to cause engrave marks, that you probably don’t want. You can see them better in @geek2nurse’s screenshot.
Yah, I was going to say the same thing as @geek2nurse and @jbmanning5 , lotta nodes in the text. I would probably try doing a simplify operation on that text, or running the smooth tool over it (in AI… not sure of the names of similar tool in Inkscape). Or just freehand a new version of the text with the pen tool using the original as a guide.
the other thing you might try in addition to removing redundant nodes is to put a box around the entire array of boards, set to a unique color, and ignore that step in the GFUI. it seems to like enclosed shapes better than a lot of loose shapes (even if those loose shapes are closed paths)
