Fast Forward option
Is there a skip feature? I somehow lost connection at the tail end of a 2 hour design. Is there a way to fast forward to the unfinished section instead of doing it all over again?
There is no skip function. Some have covered up what has already been engraved with foil and restarted. The foil protects what was already engraved so it engraves smoothly. This has been requested in the past.
If you created the art you can also edit to remove what’s already been done, and then place the edited piece over the original art in the GFUI - set the original to ignore, and run the edited piece.
Keep in mind you’re lining up to the lines in the GFUI - not to the art on your material. The former will line up perfectly, the latter is less guaranteed!
