"Filled Shape is Open"
homewodog
Can someone help find the open spot? I’ve done this multiple times before and never had an issue. I had a break from working on projects and now I’m getting this error. It will let me score, but it will not let me engrave.
What design software are you using? Rasterize the file and it should work for you.
I would guess it’s the lines at the top and bottom - those are lines (and still objects at that) so they can’t be engraved. Here they are made to be just a touch thicker, and paths. See if you have any issue.
homewodog_V2
Your graphic is fine!
homewodog_v1
This one worked, too. It only allowed one selection for solution.
