So in making (or attempting) the6061 Aluminum Bench Dogs for @markevans36301 I tried to film the process for him. And ran into the issue of filming through flood coolant with the GoPro. So I designed an air-blast system to clear the lens:
Great idea. Well done!
Note I have a custom flood coolant rig that I built that greatly increases the flood coolant pressure and flow over the stock flood coolant option (and a much larger reservoir) It also adds 3 nozzles which are larger diameter than the stock nozzles and with the added flow results in a huge amount of spray.
This is a wonderful side quest but begs the question of how goes the primary mission?
Working on it. Maybe your bench has slightly different dog holes, but when I take the ruined one it’s a very loose fit into my craftsmen work bench
There are several standards which I guess means that there is no standard. These will seem undersized if tried in a table made to the Festool spec.
I both miked mine and lifted the spec from Kreg so if they Mike out as specified they are right.
Well at least before the part got shredded when it popped out of the softjaws
That is dead on for Kreg.
