bwente
March 30, 2021, 1:57am
#1
I thought I would share an illustrator file to show how to make a box with boolean operations. If I had just shared the the SVG then all you could make is the same box. With this one, you can adjust to your needs.
file-box.ai (1.1 MB)
I made one of the friction tabs longer, to prop it up at a slight angle.
The green shapes are for “unite”, the red for “minus”.
Thank you so much for this box generator. I will use it. Those are some nice files, by the way.
Not sure how it works yet, but I will figure it out eventually! Thanks.
cynd11
March 30, 2021, 12:17pm
#4
Great idea! This would allow you to kerf adjust before doing the Boolean.
djfb
March 30, 2021, 4:42pm
#5
I could use this for some carving chisels I own.
Pearl
April 3, 2021, 11:09pm
#6
Thanks. I always appreciate AI files so I can easily edit them.
