Guys, me again…
I’m cutting some rocket motor mounts for a friend of mine who does rocketry competition. The design is REALLY tight, to fit all the components into the size constraints, but it works and I can happily cut it in draftboard. The problem is, when I need to cut it in 1.5 or 2mm plywood. The cuts are too large and the thing falls apart.
I’ve attached the file for reference, but what’s the best way to keep the cuts as thin as possible? I’ve set the material thickness as per the measurement, but it just doesnt want to know.
Ian
motor mount x 3 v2a.pdf (52.3 KB)
