The wings are on the front layer, while the art is glued to the back layer. Since the back layer is just the center circle area, the wings float 1/4" off the wall when hung. It took about 40 minutes to cut 8 of these from 1 sheet of cherry plywood.
I use fractal renderers to design them. The ones you see above were made with Fractorium and Ultrafractal. However, on a couple I took an extra step and ran the fractal through a neural network to do “Style Transfer”, which gives them different artistic appearances.
Wow, love your use of color! I would have these scattered all over the house, so you see a flash of fairy going from one room to the other. Something to put a splash of color in the dark corners.
