The front handle of my Glowforge Pro has fallen off of the machine. This is the small lip that is used to raise/lower the glass top and is located on the front of the machine. It appears that it is glued on and the glue has failed.
I see that other people have posted about this, or a similar, issue in the past but did not see a final answer because the two most recent instances of this were moved to email.
You can look for “lid hinge” discussions in Beyond the Manual for ideas on how to glue stuff back together.
I personally would either use “Goop”, or track down some VHB tape - not the common automotive type stuff, that is quite thick, but the thin stuff like you get on proofgrade veneer, for example.
