Glowforge pro froze mid run, the app said the file contained text (It does not, it has text that was properly converted to path)
Now the button is stuck orange and the laser cant reset or recalibrate.
This is the second time I have had crippling issues with a glowforge since owning it, plus the ruined piece of marble I was engraving since it just stopped part way through!
No error message in the UI? I have also had the message that the file contains text that will be removed when it all had been converted to path, and it ran fine, so I donāt think that is part of your issue. The yellow light is triggered by several things, most often it is a temperature issue, and that most often has been too hotā¦ but a cold garage might exceed the minimum. In the case of too hot the machine will pause until it is cool enough to resume, and it will continue where it left off.
In an error report it helps support if they know the date/time/time zone of the attempt to find the machine logs to examine.
Big drag about that marble.
Youāll probably want to make sure that the ribbon cable is laid correctly in the tracks, (no twists or kinks), and that the cable is clicked into place. (It shouldnāt come out under normal use.)
The ribbon cable is one of the most frequent causes of that orange light (behind temp). Something to pay attention to when removing the head for cleaning.
As for the text warning, a lot of times just an errant click with the text tool will leave a placeholder for text, which will be identified in the file as text. Basically, itās just analyzing the files code for text/text fields.
Since they did that temp software change mine keeps freezing and pausing. I did the fan clean etc and still does it. Not a happy camper. I have lost a lot of material due to this freezing.
Must need a jacket in your space. My Pro doesnāt get a Too Cold alert until its below ~51F. Have never had my spaces warm enough to see a Too Warm. Usually below 65F year round (basement in the mountains)
The cable was in its track, no kinks twists or obstructions.
I have not not re moved the head for cleaning in a while AND i just did a few prints right before it happened.
That is why it took me a bit to realize it was a physical problem and not something software related
Thanks! That makes perfect sense, across the evolution of a file with text I will often jocky with the text box. How would I check the file for those issues?
I donāt recall what the default select options are in Illustrator, so Iām including that info just in case you canāt do this with the default select options.
For this, I just made some text and turned it to outlines as we normally would. Below that, I also made a click with the text tool and deleted out the lorum ipsum (in the CC version of Illustrator, it leaves the lorum ipsum text if you escape out, or whatever. In older versions, it would just automatically leave the blank text box).
To find these text objects, I would go to Select > Object > All Text Objects (as mentioned, Iām not sure if that is a default select option, or if itās from my Plugin)
That gives a visual indication that you have an empty text path. A good practice though with any of the files in Illustrator, before you send out to SVG and to the Glowforge, is to go to Menu option Object > Path > Cleanup. That will delete stray points, empty text boxes, etc.
Iām glad you were able to get back up and printing. Could you check on two things for me?
First, the ribbon cable should connect firmly to the laser head. If that came disconnected, Iād like to make sure that the clip on the cable is seating properly in the connector. If it doesnāt āclickā into place when you insert the connector, please let me know.
Second, while it is very rare, it is possible that the ribbon cable is catching on one of the screws in that channel. With your Glowforge powered off, could you move the head from the far left to the far right and back again? Let me know if the cable catches on anything as the head moves.
I think youāre onto something. Iāve been having a terrible time trying to figure out why my unit has been stopping mid cuts, and this perhaps is related. Iāve emailed support with all of my troubleshooting steps thus far and am looking forward to hearing back. Iāve pretty much exhausted all of my own ideas, and have tried many different suggestions in the forums. I at least know itās not my files as Iāve cut these files in the past without any issues.
If it is caused by the temp software change, clearly thereās a bug in the deploy for some reason. Iād love to be able to roll-back and see if things are fixedā¦ @jae What do you think?
Hi @joshua.henry. We try to keep topics in Problems and Support to one issue per thread, but we did receive your email and weāll be following up with you there. The issue youāre reporting is distinct from the one @Eric.H reported and Iād like to make sure we keep his support thread on track and that you get accurate and helpful information for the problem youāre encountering. You should hear back from the team shortly.
Itās been a little while since Iāve seen any replies on this thread so Iām going to close it. If you still need help with this please either start a new thread or email support@glowforge.com.
