I normally adjust for kerf in Fusion these days but a couple of suggestions.
There is a plug-in called laser dfx you can install and do your adjustments.
Make sure that you have the latest version of Inkscape and always choose from file for scaling the import.
What software do you use to make the fusion files into SVG? I think I will get that plug in!
I use Inkscape if using that plug in but if you learn to adjust right in Fusion you can use a plug-in written for the Shaper Origin and it exports svg directly!
So, I can tell you the difference between the files, at leastā¦
The Squarefusion.svg that you uploaded isnāt defining any units.
The second, Inkscape created file, defines MM in the viewbox, which gives the other sizes in the document a definition to their size.
FWIW, the unitless SVG comes into Illustrator as 159mm.
Where is the SVG without units coming from?
I thought it was F360->DXF, DXF->Inkscape->SVG, SVG->GFUI
I believe that file was F360>DXF>Inkscape>SVG. It would seem itās exporting out the DXF without units and Inkscape doesnāt assign it units on the conversion.
I donāt know Inkscape well enough to say what to do there.
That doesnāt compute. You have to select a unit scale when importing any kind of file into Inkscape, you choose between āin fileā defined or manual. At that point, itās just another SVG - with defined units. I canāt fathom any way to get into the app without a scale of some type being defined.
Iām by no means an Inkscape expert, but Iām no ācomputer newbieā and have been working with CAD-style software for over 30 years.
Iām just saying what the SVG file says - it has no units defined, which probably defaults to pixels, without a unit designation.
Which is why it comes into Illustrator at a different size, the UI as a different size, etc. because they all use different DPIs.
Understood. Not disagreeing, just wondering how that is possible when Inkscape works in units - whether it be traditional measurements or pixels, it is defined.
Yes, SVG defaults to pixel dimensions (well, technically āuser unitsā but thatās normally the same as pixels). SVGās heritage as a web technology makes some of its design choices unfortunate for āreal-worldā use.
I suppose the lack of being defined, means that itās by default interpreted as pixels.
Hereās the file that originated in Inkscape:
Hereās the file that originated in F360, to DXF, to Inkscape, to SVG:
I hate using Inkscape (mainly because it sucks on the Mac and I donāt know my way around it)
Hereās what I get when I open up the document properties for the squarefusion file (which is the F360, DXF, Inkscape, SVG file)
Which shows the default to pixels without a unit designation, as @tim1724 confirmed.
I do this workflow a lot. However, instead of opening the dxf, I āimportā it into my blank āGlowforgeā template (20x12 units set to mm with a few guides for āwill not printā areas) and then save that for import into GFUI.
I assume that when you design in fusion you are designing in mm. It is starting to sound like the issue is that inkscape can open the fusion dxf but wonāt save it with the proper units unless it is imported into an inkscape file that has mm as default. The importing and the default mm being key. I will try this and let everyone know how it turns out. I do very ch appreciate everyone helping out! This community is great on a lot of levels! I like that we donāt donāt leave fellow GFāers stranded!
That sounds right, except my F360 file was mm, and my default Inkscape unit is mm as well. Iām very confused but hope we can find a path that works consistently.
Which version of Inkscape do you have installed? There were some sizing issues with earlier versions. The most recent ones (0.92) eliminated it, IIRC.
I thought I was running .92 but the about page shows .91 and a bird?!?. Will upgrade, too! thanks of the tip!
Oh I am on .91 because I am on a mac. As best I can tell there is not a .92 for mac yet. I an not that savvy when it comes to the alternative methods that might get .92 for mac so I will stick to .91 for now. I will check out the fusion apps that @markevans36301 suggested.
I do know that .92 they changed the default DPI to 96 vs 90 in .91.
I am also on Mac, and am running .92.2 (available since August last year)ā¦
For some reason the Inkscape macOS download page continues to incorrectly state that 0.92 isnāt available despite the fact that itās been available for nearly a year. Hence the confusion.
The latest macOS release of Inkscape is 0.92.2, found here: https://inkscape.org/en/release/0.92.2/platforms/
Other platforms have 0.92.3 available (change the 0.92.2 to 0.92.3 in that URL) but I donāt see a macOS version of that yet.
