Breadboaring circuits is great to play around with getting your circuits tested and working but you can’t really put them in projects too easy. The next step is normally make or get made a PCB or move everything to a perf board. I don’t really like perf board so I thought I would make a custom perf board. I got a sheet G-10 Garolite .030” and a sheet of Phenolic from McMasterCarr. I searched around the web to see if it was safe to cut and found mixed opinions… so I went for it.
Nice! Soon you will have a pile of circuit files! FILES!! @dan! Folders - PLEASE! Move that to the top of the Hopper. That would be a massive enhancement to the UI!
Well, that’s actually not dead bug construction. That’s a very specific technique where you have a PCB with errors or you need to test something, and you add the IC by flipping it over and sticking it’s little legs up in the air and soldering wires directly to it.
