Has anyone ever engraved anything like this for someone? Need to engrave the gavel and round strong text
I haven’t done any with the GF yet, but most that I’ve done with a rotary diamond tip engraver before had a removable brass piece that wrapped around the center and was held in by the handle. You if it has a removable piece then just mark your center and edges before taking it off and you’ll know your marks.
Also use caution with the brass as it is reflective like copper. You’ll have to research that as well because I haven’t done any brass or the research on it myself.
If you have a portion of the gavel that is a normal cylinder then you can engrave a piece of veneer and then wrap and glue that.
Not marking the brass just the wood.
