This is something someone here should be playing with, if they aren’t already:
When we last spoke to Orli Tesler and Itamar Mendelovitch, the duo explained how they developed their technique of making wood veneer act like a textile through a series of diagonal crosshatches.
Thanks @evermorian! The first thing we found is that, while its pretty cool and bendy toward the felt backer, it doesn’t do what Tessler+Mendelovitch’s product does. They’ve CNCd a bevel into all the triangle edges so the material bends equally in both directions. I’m afraid the laser just doesn’t do that so the 1/8" material runs into itself across the distance of a single kerf. (3D engrave aside as that seems like a horribly inefficient use of a laser). The next experiment will be either cutting a pattern into veneer or with a second cut line to space the triangles apart.
I think you’re correct. From what I read about the two architects they attach both the clutch size and wall size versions to a flexible backing material of some kind.
Do you think if you flipped the design over after cutting and pushed all the pieces back together then cut over the already cut lines it would apply enough of a kerf bevel on both sides?
It’s a good thought but in the current iteration I don’t think so. The bevel on 1/8” cut material is so slight it’s almost negligible.
From their photos and videos I’d guess the large scale T+M woodskin bevel is around 30 degrees. At small scale I suspect going to veneer thickness would yield bendier results.
