Hello! I am having a bit of a design problem. I’m using Inkscape. I want to place artwork inside of a circle, but when I click “Union,” the interior artwork becomes whited out. I want to create something like this:
Have you subtracted the inner circle from the outer circle first, to make the frame a single object? If not, it’s just going to add all the shapes together to give you a solid.
It’s not clear that it’s a “donut” here. I suspected it’s just a single wide-black-stroke circle with no fill. For all we know it’s a filled black circle with a slightly smaller white filled circle on top of it, with a Christmas tree on top of that.
We can’t know for sure until we see the file.
Also @gseverino, @geek2nurse might be right, and if you want to try it “subtract” is “Path->difference” in Inkscape.
I want to thank everyone for their help. I solved it by creating a circle, duplicating it, aligning and centering the two circles, clicked “Difference,” and then used “Union” for the image pathed object. It worked well. Here’s the final image:
I engraved the image because I was afraid of it literally falling apart!
