I’m walking through the set-up process and am in the “learn by doing” section where it walks you through your first cut, and cutting the “Gift of Good Measure” key chain.
In the instructions, it tells you to sign into https://app.glowforge.com, then hover over “Gift of Good Measure Key Chain.”
When I’m logged in, I land on the attached page, and there is no “Gift of Good Measure Key Chain” image to hover over and select??
I’m so sorry you’re having trouble getting set up.
Could you please try the following steps?
Power Up: Turn your Glowforge off. Then turn on your Glowforge and wait until all motion has stopped for 30 seconds.
Start Wi-Fi Setup: Hold down the button on your Glowforge for ten seconds, until it glows with a teal color.
Sign In: Using a Wi-Fi device like your laptop or tablet, go to setup.glowforge.com and sign in.
Connect Your Glowforge to Wi-Fi: Follow the instructions at setup.glowforge.com to connect your Glowforge to Wi-Fi. If you run into trouble along the way, let us know what happened right before the issue arose.
It may help to take a look at our Wi-Fi troubleshooter as well. If you run into any other trouble, please let us know.
I will try this - I bet that’s the issue as I don’t think it was fully functioning on wi-fi yet when I tried it.
Once I get back to my studio I will try again. (I figured I’d better take a break now before everything is fully working to eat and sleep, before tomorrow hits and I don’t want to do anything but play!)
I’m glad you resolved it! I’m going to close this thread. If you run into any other trouble, please start a new topic, or email us at support@glowforge.com. We’re here to help!
