I’m having an issue with my GF Pro that I hope you all can help with. Either I’m going crazy or my GF is messed up. I tried cutting the serving tray with wooden handles. But it keeps cutting larger than what is said on the screen. I used a PDF file and made sure my 1-inch squares measured 1 inch. This is not the only file it’s happening with🤔
Any input is appreciated
Are you checking the measurements with the measurement tool in the interface? What is the size difference between the 1" in the pdf and the actual output?
Can you share a screenshot of the file on the interface? How was the file created? If you make a 1" circle in the interface does it cut as 1"? Can you share a file that is resizing?
Have you cleaned your machine recently? This happened to me. After cleaning the machine, including taking the carriage plate off, I put belt back on and got it twisted which caused the machine to cut out of scale. I would check to see if the belts are twisted.
