Turned gf on lights but no movment from print head whats up with that
Does the interface say offline?
yes
If it says it is offline, you will have to investigate why it has lost contact with your wifi. You can try resetting your router, using your phone as a hot spot and/or going through the wifi setup application to see if you can get it to reconnect to your wifi.
