GF officially set up & running, or NOT. Attached is a pic of the very first three test cuts from top to bottom that I made on GF proofgrade. I ran everything at factory settings. (#1, 2, 4 directly from Glowforge library)
Gift of good measure
Puzzle
*random block letter
Pendant was supposed to cut around outside & half circle but didnāt. I also tried another āgift of good measureā & it engraved but didnāt cut.
**For a CUT, itās not cutting 1/4 of the way through the 1/8" wood. Itās like the laser has no power. Has anyone experienced this? Suggestions? (Lenses were cleaned AFTER it quit cutting. ).
Check to make sure you didnāt get the lens in upside down after cleaning. The cut lines on the two unsuccessful cuts look way out of focus. Thereās a little arrow on the side that points up to show you which way it goes in.
Did you use the honeycomb pins to hold down your board? Wondering if your board is bowed versus flat since the problem areas are more towards the middle. I can find the link to the pins if you donāt know what they are.
