For two days I can’t cut. The screen Is stuck on “rendering your design”. I have used two different WiFi’s, two different devices. If it does open, after hours, the screen is stuck.
Any advice?
Any advice?
have you cleared your browser’s cache? that has helped me!
If rendering takes more than a few minutes then it is stuck. Close your browser on all computers/phones. Clear the cache, and then load a known good design (Gift of Good Measure for example). Once it loads successfully, you can try your file again. If it sticks again then likely there is an issue with your file.
@craftsofadifferentsh
I’m so sorry to hear your Glowforge app is stuck on rendering your design.
I extracted logs to look into this issue and it looks like you have been able to connect and print since contacting us. That’s great!
I wanted to follow up with you and make sure everything was working and if you had any other questions.
Hi! Yes all is well and solved. It was thrcresign
Oh that is great it was a simple fix!
