Gingerbread Clock... Mostly finished
It took me quite a while to deconstruct my 150 year old parts clock… Figure out how to update it a bit… make pieces I couldn’t just buy… But now I have a nice set of illustrator files to make more so it shouldn’t take me 4 weeks to finish the next one. :slight_smile:
This one actually still needs the hinges on the door… And some touchup in spots. But at least for today… It’s finished.
Sweet! :cake:
What parts did you end up making? Did you engrave the glass in the door? That looks a little to precise to be 150 yo :slight_smile:
Every bit of wood is laser cut except for the molding that’s glued and nailed to a laser cut box for the base. The “glass” is actually my last piece of proof-grade acrylic. All wood is glued and where needed, 5/8" brads.
I 3D printed the bezel. I designed the clock face in photoshop. And the movement is purchased off of amazon. Other than that… All glowforge. :slight_smile:
Wow. Even more impressive.
I figured the clock face was the one thing you didn’t touch. :smiley:
The original face was glued to a metal plate which the bezel was an integral part of. I tried finding something to use but eventually just decided to design the bezel in fusion 360… 3D print that. Then printed the face I designed to look antique and distressed on 100# bristol board on my Epson P600 9-color printer and glued it directly to the birch ply that I cut everything from (aside from a few pieces of 1/4" MDF for certain pieces). Used gorilla glue to affix the bezel in the same way. Directly to the birch.
Everything got a black cherry stain. Nothing was sanded or finished in any way really. I wanted it to have that antique look to it. I even thought about beating on it a little bit to make the wood distressed as well, but decided against it. :slight_smile:
Original Ansonia clock face
Pretty! :grinning:
Really nice! I love a good clock!
Wow. That really turned out great!
So much detailed work - great result!
NICE! Looks awesome
Looks wonderful! I’m sure you’re enjoying the process!
This clock is really outstanding! Clearly a labor of love. I really like the job you did on that face.
Now I’m wondering how on earth you did the curvy bottom molding on your Glowforge?
That… is the only woodwork not done on the GF. Standard off-the-shelf pine molding from Menards. :slight_smile:
Is ironic that the 3D printer is the stand for the antique clock? :thinking:
Seriously though, fantastic use of new tools to create a functioning work of art!!!
Nothing wrong with that!
Haha. I thought about that after I took it. But it was the only flat spot I had on my desk big enough to put it. :smiley:
LOL! I live in that same world!!! Never can find a empty spot… To many projects… not enough time or space!
