Glowforge aura won't refresh bed image
HELP!! I can’t refresh the bed image, is there any new ideas other than cleaning and the WiFi? I tried what seems like everything. And I’m getting an error message. I’m so frustrated right now. I’ve only ever completed about 5 projects on it and I have had it less than a month.
Welcome to the community. Unless you’ve already done this, I suggest you close out your browser, shut your Glowforge off, then just start all over. You don’t say what the error message is, though…that might help us help you.
The error message says " We’re sorry, and unexpected error has occurred. If the issue persist contact support with details about what’s causing this error to occur
That sometimes comes up when there’s an issue with your design. In addition to @Xabbess’s suggestion about turning off and closing out - I’d manually clear the cache on your browser. Sometimes when it has an issue, it doesn’t actually reload the page from scratch so you get stuck in a loop.
If it comes up again after doing all that, try loading the Gift of Good Measure (as it’s a known-good design) and see if that loads ok!
Ok, Thank you! I’ll try that and see if it works.
@ deirdrebeth I cleared my cache and restarted the wiFi, powered off the Aura and rebooted my computer but still nothing. Any more suggestions?
You might try using a different browser. Chrome seems to be the most compatible with the GFUI, but it you’re already using that, you may have to contact support at 1-855-338-2122.
Thank you!
