Engrave fills enclosed vector shapes. That’s what it’s designed for.
As stated, you can use “score” (which is just a reduced power cut) if you’re just looking for a thin line. If you are looking for a thick line, similar to your image, you can either run a defocused score as also stated above, or change your design to have “an arrow within an arrow”, and it can then engrave the space between them.
