I have had my Glowforge Pro for about a week. I have not been able to do any etching or cutting, due to the fact that unit drops the connection from my wifi network and reverts back to the built in access point. This behavior is repeatable, as I can follow the setup procedure, have it running on my wifi network for a few seconds, and then it just reverts back to the access point. Glowforge tech support has not sent any email or given me a phone call to help resolve the problem. The only email I have received, is an issued trouble ticket number, which appears to be computer generated.
I don’t know why Glowforge chose to make a network setup of this type. The setup would have been a much better experience, if Glowforge would have installed a light weight web server to log into for the setup, the user could assign the SSID, passphrase, and assigned a static IP address, or opted for a DHCP assigned IP address. This is a setup that most end users have experienced, with other computer peripherals.
One possibility: GF prefers 2.4 GHz network to 5, so check your setup.
I recently had to update my Xfinity modem, and they are trying hard to push folks to combine settings, figuring each device is smart enough to know if it needs 2.4 or 5GHz. Don’t believe that, keep separate networks for each speed.
Thanks for your response. My wifi network is 2.4 GHz.
My Glowforge goes through the setup just fine, it just drops off my network after a few seconds and reverts back to the built in access point.
I get the “huzzah!” and the confetti page…
But my Glowforge continues to drop and revert to the built-in access point.
It’s repeatable, and I have tried the setup about 30 times.
I’m so sorry you ran into trouble during setup. It looks like your Glowforge is connected and you’ve been able to print since contacting us. That’s great!
I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
