âSave Asâ and âExportâ are intentionally different, because theyâre intended for different uses.
âSave Asâ is intended for sending the document to someone else to work on. Thus it saves the document into a format with all of the metadata required for someone to load and keep working on the document. If you âsave asâ an SVG file, itâs got tons of information in it beyond whatâs required simply to render the image, such as hidden objects. For example, Iâm generating many objects with the same cut but different engraves, which I put each on a separate layer, so I can easily hide all layers except the cut layer and one engrave layer. When I âsave asâ the output file contains all of the layers, so that if I open the SVG in Illustrator theyâre still there. IMO, the use case for âSave As SVGâ is a bit obscure - most of the time you want to work in Illustratorâs native format.
âExportâ is intended just for rendering. So it can output to a bunch of bitmap formats, and when it writes an SVG it strips it down to just whatâs needed to display the image, with all of the hidden objects and additional metadata stripped out. When I âexportâ the same document I used as an example above, I get just the cut layer and the visible engrave layer, and the file is much smaller and simpler. If I open an exported file into Illustrator, it has nothing but the visible objects - all of the hidden layers are gone. And thatâs a good thing, because the file is (in this case) 1/10th the size, making uploading and processing in GFUI much faster.
So what Illustrator does isnât being imprecise, itâs being quite precise for two very different use cases for SVG. Either you want all of the hidden objects and metadata of an AI file, but written in SVG (perhaps to send to someone using Inkscape?). Or you want to send something compact to efficiently render, such as for printing or use on a web page. For GFUI, thatâs what you want.
The SVG from both âsave asâ and âexportâ are valid. The difference is that the SVG written by âexportâ is stripped down to just whatâs required to render/print the image, while the SVG written by âsave asâ has a lot of additional info in it so as to represent everything in Illustrator (hidden objects, tons of metadata, etc.) for continued editing. So both will work, but the smaller, simpler file generated by âexportâ will be faster to upload, faster to process, etc., so in general itâll work better. For a specific example, I have an Illustrator file thatâs 12 MB via âsave asâ and only 2.5 mb via âexportâ. The 12 MB file fails in âprocessingâ, and the 2.5 MB file works fine.
For a file with no hidden layers, the âsave asâ is still bloated compared to the âexportâ file, but itâs not so dramatic. It takes longer to upload and process, but not dramatically longer, and not failing.
TL;DR: âIn SVG, there are two types of coordinates, those defined in user space and those defined in real world units. If no unit is specified, it is assumed to be in user space units. By defining the document size in real world units and applying an equivalent viewBox attribute, one can define the user space unit to be a real world unit, e.g. millimeters.â
Since SVG crosses so many domains, units can get really messy. The supported length unit identifiers are: em, ex, px, pt, pc, cm, mm, in, and percentages. So if youâre designing for screen. print, or fabrication you work in different units (traditionally). And some of the units (pixels, em, ex) are completely context-dependent, so their meaning changes depending on what font youâre using, what dpi screen resolution is configured for, etc. Then you can mix them into a single design, which is all kinds of confusing. The spec https://www.w3.org/TR/SVG/coords.html is mind-bending. But Iâm sure itâs precise, given that itâs from the w3c. But icky. I thought date/time was messy⌠whew!
Date/time is still messier. Time zones, daylight saving, leap days, leap seconds, calendar systems that disagree on the number of days in a year, etc. Not to mention calendar systems where the numbering of the year depends on who is emperor or calendars where the beginning of the month depends on whether someone in a particular location was able to see the crescent moon or not at a particular time.
Itâs interesting that Illustrator seems to be relying on that assumption as well when the user opens a file that was saved as. Presumably a 1 x 1" artboard would have⌠width=â72pxâ height=â72px"
in it, but what would it spit out if you set your artboard to 1.0069 x 1.0069â (slightly less than 1-1/144" square). Would it say â72.5pxâ? â72.4968pxâ?
Not entirely. I was pointing out the disconnect between the authoritative âSave As should not be usedâ with the fact that itâs been used successfully for many thousands of files in the last 9 months of real life use of the GF by many many people. The implication that all those projects did not work, could not work, should not work and all the people using that method (recommended by GF by the way) are doing it wrong because an individual who spelunked the SVGs thinks he has an explanation of why they all canât be doing what theyâre doing flies in the face of reality.
Iâm perfectly fine with suggestions, recommendations or observations but pronouncements of absolutes in the absence of all the facts (and since none of us have access to the GF source code, weâre only guessing as to how itâs handling things) is the height of hubris.
âShould not be usedâ is quite a bit different than âcan not be usedâ. If @chris1 had said âcan not be usedâ the fact that it actually can be used would be a great retort.
Really trying hard to stay up on this amazing topic and important issue. I appreciate your tenacity because it has been enlightening for so many issues. Iâm thankful that you are putting this effort into the forum because much good can come of this.
Are we talking about recommended best practices? In the sense that, if we are all starting from scratch with the same learning curve to deal with, export is the better habit to use for making GFUI ready files for several reasons. Save as works but causes a file description that might be more open to problems.
I am think about qwerty keyboards versus colemak keyboards. Anyone with a smidgeon of statistical acumen would be insane to endorse qwerty over colemak or some other letter frequency/home position based layout. And yet, what do we have? The burden of legacy infrastructure and educational/informational pathways. It pained me each year when I taught technology to elementary students. I knew I was teaching them a less efficient method of touch typing, and yet I still did it. It works well enough. Enough that it balanced out the hassle of learning to reconfigure keyboard layouts in software and on the hardware itself and being prepared for the rest of your life to have to roll your own.
There is the ideal and there is the real. I do believe we can agree on best practices, but personal workflows will be personal workflows.
But maybe I have totally missed the point here. Sorry if my narrative has nothing to do with the issue at hand.
Our advice remains to use Illustratorâs âSave Asâ feature exclusively for preparing images. Youâre welcome to use other approaches. Should you find a bug, weâll ask you to see if the bug exists when using the Save As approach. (As with any advice, itâs possible weâll change this at some point in the future).
Until GF comes out and says âsorry, we were wrong, donât use the Save As method as we previously told you to, use Export instead despite having also told you before that you shouldnât use Exportâ, theirs is the authoritative comment on the subject. This is the objective reality that matters - there are no alternative facts in play. Just who to believe, the authors or the observer.
EDIT: Looks like Dan weighed in with some additional authoritative support
Chris a long way back I had a job that failed to render correctly, and ultimately it was discovered that it was because I had used export rather than save as. Once I switched it worked fine, and we were told to use save as by support⌠there was a lengthy discussion in early pru days about the differences and why save as was the right thing to use. And every ai project since on Prus has used save asâŚ
Dan has mentioned several times in the past not to use the export command as it introduces issues, try searching âIllustratorâ and âSave Asâ or âExportâ
He said it again tonight in response to Chrisâs admonition not to use Save As. Said you can do whatever you want but if you have a problem Support may ask you to try again using Save As.
