I know theyāre working on it now, but I donāt know any more than you do when it will be ready.
Is this something you have commissioned?
Oh no, Iām just a hobbyist. Just a lot of projects I had planned for full bed stuff, you know?
Yeah, Iām just a hobbyist too, which does take some of the pressure off at least.
It will get better, and in the meantime, thereās still a bunch of fun things to try. Give reducing the LPI and ppi a shot. Might work. Canāt hurt.
Will it destroy the resolution of the image? I will admit itās a complex image to translate to engravingā¦thinking was if I could pull this one off I could pull anything off on this thing.
Changing the LPI down to 195 wonāt do a thing to it - should still engrave perfectly. If you havenāt done that yet, thatās the first thing Iād try.
You also want to take it in steps when you get it into the interface - just engrave the largest one first with all others set to ignore, then turn one on at a time. Donāt move the material or the placement of the images on the screen in between engraves though, and donāt exit out of the file.
oh ok, I wasnāt sure what LPI actually didā¦So if it wonāt do anything to it, what does LPI do?
LPI (Lines per Inch) is the number of times per inch the head travels back and forth. At higher LPI values, the beam passes over areas it has already burned, so you donāt actually gain anything from a burning standpoint, the hole just gets deeper. (Itās useful for 3D engraving - not as much needed for image rendering. In my opinion.) And it generates a LOT of additional data for the buffer to have to deal with.
I explain why itās a problem for large sized engraves in another tutorial here:
Well then. You are a font of information. Thank you Jules. Iāve utilized a number of your tutorials for learning how to do things (didnāt know how to use photoshop/illustrator AT ALL when I got my GF for example). Thank you very much.
I love hearing that - we always need more designers in the world! Canāt wait to see pics of your project!
I read the tutorial you linkedā¦Will it treat the gradients in PNG the same as like a BMP for depth engraving purposes?
Depends on whether you choose 3D engrave for the bitmap image or dots (dithered).
(You want to use dots for a large image.)
What if I do neither and just do the grayscale by varying levels of power which is essentially the same as the Proofgrade 3D engrave setting?
Also, random aside, what do you use to dry off your pieces after you soap and brush the resin off? I find i get little particulates of towel or whatever on it and am trying to avoid that.
I believe Iād stick with the dithering. (dots). Donāt know if it will process a full bed 3D engrave.
So, I used rectangles to make little square parts of my imageā¦Had about 20 of them, they were perfectly aligned in illustrator/PS, the image looked as one (they were all separate layers) but when I imported it into GFUI, it has little tiny lines separating them. I thought maybe it was just a UI thing but would print without them, but no success, it printed the little lines. Any idea why it does this but not with the magic wand function?
