You have opened a support ticket already by making this post, so please don’t email support as it will create duplicate tickets that slow down their response. A support representative will be along soon to assist you.
Did you check to see if you blew a breaker? I would check that first, but be sure your machine is unplugged/off.
Beyond support:
I literally just unboxed my glowforge and noticed that there is a fuse next to the power switch. I would unplug my machine and check to see if you blew the fuse. (however I am an electrician, so if you’re not sure what you’re looking at it may not help)
I think what you are looking at may be the safety interlock if you have a RoboxPro. I don’t remember seeing a fuse next to the power switch on my unit.
The fuse next to the power switch mentioned above is only on the Pro model. If you have a Plus or Basic there is not one.
Support will be able to pull the data logs for your machine but they will need to know what time, day, and time zone the problem originally occurred. If you go ahead and edit that info into your post it may speed up their ability to get you some help.
Oh no! I’m so sorry to hear that your Glowforge isn’t powering on.
Your Glowforge should be plugged directly into a grounded wall outlet that meets local building codes. If you haven’t already, please do the following:
Unplug your Glowforge from the wall
Plug another device directly into the same outlet and see if it works
If the device does not work, have an electrician investigate. It may be a blown fuse, a broken outlet, or something else
If the outlet works, unplug the other end of the cord from the Glowforge unit itself
Inspect both ends of the power cord; if you notice any damage, try another power cord
Plug in the end of the power cord that goes to the Glowforge, making sure it is inserted all the way in
Plug the other end of the power cord into the outlet, making sure it is inserted all the way in
If your Glowforge still won’t power on, try another outlet
Unfortunately, it looks like your unit is experiencing an issue that we can’t resolve remotely. I want you to have a reliable unit, so I’m recommending we replace this one.
I’m closing this thread, and I’ll be in touch via email very soon to sort out the details. I’m so sorry about the bad news.
