I’ve been having issues with my Glowforge not cutting all the way through on proofgrade materials and am really getting frustrated since that’s not supposed to happen. It cuts on SOME of it, but barely all the way through. I’ve had this issue before and my machine is only a couple of months old. It’s clean, etc. I’ve followed all the tips, etc. on the site, but still having this issue.
Support will probably ask you to run the “Gift of good measure” on med draftboard to further troubleshoot.
As a short-term workaround, however, I suggest you use a corner of your material to figure out settings that work before running jobs that use up significant amounts of that material.
Be sure you’re using the hold down pins or magnets to ensure the material is truly flat against the crumbtray–you can hear the difference between areas that are touching the tray and if there’s a gap. I’ve found most PG boards (except acrylic) are rarely perfectly flat on their own. I got one that was over 1/8" difference from center to edges.
Also be sure your lens was installed into the head the right way–it’s easy to put it back in upside down after cleaning it (yes, I figured this out myself after I had issue w/ cutting thru).
Also pending your climate, higher humidity areas (e.g. Houston) vs. Seattle will require a bit slower speed than PG setting for full cutting.
I’ve had the same issue with numerous PG materials. I have about 6 sheets that have large sections that are ruined because the GF didn’t cut all the way through or engraved too deep. And I’ve only had it recognize the PG material 3 times. Every other time I’ve had to go in and select the material.
You will want to start your own ticket - support might not see it here. (A New Thread created in the Problems and Support category will create a ticket for you.)
