I have noticed that today IST 10:30pm onwards my prints have become starkly quieter, without any change in settings.
Is this some issue or some OTA software update resulting in quietness?
P.S. results are still the same.
Attend a rock concert or go to the firing range yesterday?
I wonder if your exhaust isn’t working well? Not sure if you’d be able to tell if there was a difference, but you might want to check. Could also be the head fan? Is the smoke blowing the way it always has?
Make sure you didn’t accidentally select Compact Filter Attached under the gear icon once you have a design opened. That will knock down your fan rate really low. You don’t want that selected unless you really do have a Compact Filter attached.
Its working fine. I don’t see a problem. Even if i want to check , how should I be doing that ?
Thanks. Its resolved. I had accidentally selected the compact filter attached.
Thanks for the answer @cynd11, that’s right. I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
