Good to know!
Yuuup. Every instance I’ve seen of this, it has always occurred in the lower right corner.
I know @jbv has experienced this, and I have lost a couple sheets of material to it as well.
I just stay out of that corner if possible.
Huh. Funny how individual these machines are. I always start at that corner - my right side margin is less than my left side unprintable margin so I use the right side up first. Then I can slice it off and move the sheet over and I can use what would have been wasted left side margin.
I’m good with “stay out of that corner”. Does anyone know the dimensions of the do-not-enter zone? I kind of think it is 2" wide by 3" deep from the front-right corner.
I’m certainly not. This appears to be “an issue” now that needs to get fixed.
I mean, I don’t mind steering clear of that corner for a few days until the cause has been found and resolved, but otherwise…
Me too:
Hi @Tom_A,
Please don’t misunderstand. I want a fix so I can use the entire area. But I’m willing to accept the temporary workaround of “don’t use the corner.” This problem definitely does need to be addressed.
Not sure how it can be fixed because it physically can’t get to the corner unless you shave some of the plastic casing away. They would have to reduce the working area even more unless they can shift it all towards the back. I have no idea why it is so far forward when the camera can definitely see all the way to the back.
Wow – Thanks for the hint! I just confirmed it easily enough.
My test:
- Power off the machine.
- Manually move the head to the front-right until it touches the front wall/door.
- Without pushing it back, move the head to the far left. On the far left, there’s a 2mm gap between the head and the door.
The path of the head is not parallel to the door; the front door is skewed inward by about 2mm, with slightly less room on the front-right corner. This is what the head is hitting.
Wow, if you engrave a right angle is actually a right angle or is the gantry skewed by 2mm?
I’ve been making right angles and rulers all week. (Putting the media in the middle of the tray.) They are accurate.
I think the head is correct; the door is askew.
Does the door meet the front of the case square on? Or is the entire inside of the machine skewed with respect to the case?
Really hard to measure since I don’t have a right-angle T that large. But I believe the insides are square, while the outside case appears to be slightly parallelogram.
More testing… I think I know an easy solution.
You know the gray “do not use” border in the UI? (Areas that the camera can see but where the head cannot travel.) They need to pull the bottom border (bottom UI = front of GF) up about 3mm.
I don’t think anyone will complain if they lose 3mm of cutting depth.
“But didn’t you say it was a 2"x3” area?" I was wrong. The bump happened at the bottom left. That screwed up the final element – which was in the 2"x3" area.
The workaround is to just skip a little bit more room at the bottom(UI) / front (GF). If the head doesn’t bump the door, then you’re fine.
Meanwhile, GF could be modified through software to detect this issue. During calibration, move the head all the way to each corner:
- Move from back-left to back-right to back-left and measure the length.
- Move from back-left to front-left to back-left and measure the length.
- Move from back-right to front-right to back-right and measure the length.
This will identify the actual cutting region. With the bump against the door, you should notice step 2 being a fraction different from step 3. If they have a way of saving calibration settings, then this measurement only needs to be done once (or once in a while) – and not every time.
Not to be rude but that made me LMAO! The angst surrounding the increase in usable length vs the advertised capability and the accompanying change to the 11.5" height (current target) went on for weeks (and continues to be dredged up as another indication of GF’s supposed intent to deceive buyers and to play bait-and-switch games while failing to deliver).
Any further reduction will undoubtedly bring those same folks out to replay the same vitriol.
Does this apply to everybody’s machine or just a few? I.e. is a design bug or a manufacturing tolerance problem?
I only have access to one GF. (If you want to give me a second one, I’d be happy to check.) Try the same manually-move-the-head test and see what your door gap is like. Is it straight? Off by 2mm (like mine)? Or something else?
Thanks for the exploration @dr.krawetz. Unfortunately, I believe we should replace your Glowforge as this issue is likely to arise again. I’ll email you about that shortly.
