I’ve been doing wood and acrylic inlay projects, and I anticipated that these would be helpful. I got one project done with their help before my forge went and died in me, so once I get it replaced I definitely will be using these in my future work. Glad to see someone sharing the idea!
That’s a good set you got there. I have a few of those 2" size, they are really handy for fine work. I almost got a bunch more of that size, but decided that the 4.5" would be more all purpose for what I’m doing lately, and that I’ll buy the small ones if I find myself directly needing them.
I typically am only working on keychains so the 2 inch ones were more my style, but the pack I got had a couple bigger clamps as well. I figured the small variety would tide me over for now
I have a project now and again that needs a clamp further into the design, but usually with the laser it is on the edges.
Here is my go-to for laser projects.
Seems like a weird choice, but once tried they win the first grab since the laser materials are usually thin.
These are the small ones, I agree the large ones are bear traps.
Limited to less than 3/4 inch but like I said, works well for the thin laser stuff.
Have not seen any scratches on acrylic or wood damage (so far)…
I have a few super strong ones that have more of the thinner edge on the clamp as opposed to a foot and yes, I’ve messed up projects when I forget to use a flat piece in between the clamp and sides…
I have a set of 4 2”-size from harbor freight. The ones I linked to seem to be a good bit higher quality than the ones from HF. I have yet to see one of my HF specials snap off but the new ones are much more solid and clamp a lot more securely.
I use those Amazon ones. I regularly accidentally glue them to thing theyre clamping, and despite that none of them have broken yet. I feel like if things can survive me, they can probably survive most people. Lol.
I actually bought them accidentally when trying to buy another pack of these clamps. The 20 set ones are a little rougher plastic, but theyre much clampier (technical term). Plus, the biggest ones of the mixed pack sometimes require me to use two hands, which is a stupid feature for a clamp.
Typically I would add a bit of epoxy and adhere the pad back to the clamp foot. It’s not a permanent solution, but it does expand the clamps usefulness.
