i am learning still. been using my GF not quite a week yet. i would love to make some ear savers but am confused on what material and where to get it?? thanks!
It comes with a clear laser safe masking. You want to order it without any add-ons. I order 12x24 because I can cut it down but they offer 12x20 as well.
Only long term testing will tell for sure but in my quick tests, it does great because if the mask is way too tight the wings just fold and release instead of breaking.
Good call on the size. I just noticed that the 12x20 is actually more expensive and can be slower to ship than the 12x24. Thanks for the note on the masking.
This I do not know. Even regular acrylic tends to craze from alcohol and I believe that this is a modified acrylic. Hold on, I can do a short term test right now…
Okay, after a two minute soak and then a two minute wait, it shows no change in ductileness or other changes.
I have discovered that the space between the lid and front door (or under the front door?) may just work if the material is thin and flexible enough. I had some heavy nylon duck that I had trouble sticking through the passthrough, but did not need to.
This stuff can be cut with an exacto. I literally just set up my cutting mat that has measurements marked, taped the lucent to it, and used a straight piece of cardboard as my straight edge. A few steady swipes with a sharp exacto and it’s cut down. The 4" piece that’s left can easily fit more ear savers.
Lucent is a brand name for a line of semi-flexible acrylic from Rowmark. You have probably encountered it in “plastic” rulers, stencils, etc. They market it as “laser safe”. It’s not cheap.
It’s definietly not polypropylene, but appears to be a composite of proprietary polymers including poly(ethyl acrylate/methyl methacrylate) and acrylic styrene copolymer. I like the fact that the GHS health rating for the material is 5 (in the GHS rating system, 5 is the most safe rating for health).
I think I’ll give it a try. I sent several different ear saver designs (including the GF design) made with 1/8" acrylic to my son, who is a PA with an urgent care facility. The verdict was that he and his colleagues prefer a 3D-printed ear saver made with a flexible filament. The inflexible acrylic ear savers were too uncomfortable for a 12 hour shift.
I’ve got some of that but it’s a bit thin. Not sure how it will hold up. But I just got 50 sheets of 2/16" (0.060") from them that seems like a good in compromise.
I need to trim them tonight and then I’ve got another thousand earsavers to get done before I’ve caught up.
