Hey! I had to get a replacement machine (which came very quickly, thank you) but, since getting the replacement, under engrave, it does not give me the greyscale options anymore. Where it used to give you “convert to dots, lines, etc” and then the actual scale that you could manually adjust, it’s just not there anymore. Is this part of the update? AND, I no longer have the 3D engrave option…
PS I searched and searched and I hope this is not a repeat question. TIA!
save these files and then bring them into the interface. Top is a vector engrave and bottom is the same file with a gradient fill added, saved as a bitmap.
Ok, so I’m using Inkscape for most of my graphics. Would it be easier to use CorelDraw/Photo? I guess it makes sense that when I started using Inkscape and really became functional with it is when all these options went away
I use Inkscape pretty much exclusively. It will do just what you need. That gradient Church image was made in Inkscape and exported as a PNG.
Select what you want to engrave that way and then export it as a bitmap.
Are you making things with gradients in them in Inkscape? That is just fine. Just remember to export the image you want as a bitmap. It can export just the selected object, the whole design, or the whole page.
Just to clarify, you never had the option of 3D or convert to dots with a vector element. It’s always just been a single power, constant-on solid fill operation (no dots/dithering).
It looks like @marmak3261 provided some great advice on how to resolve the snag you were running into. Could you let me know if you’re still experiencing trouble?
I’m so glad the advice helped! I’m going to close this thread. If you run into trouble again, or have any questions, please post a new topic or email us at support@glowforge.com and we’ll be happy to help!
