I am having issues with the Glowforge UI, when changing dimensions under the ruler tool. I was trying to change the width and height of an object. I would enter in a value for either the width or height and instead of keeping the value I entered, it would change it to some random value. Sometimes it was higher, sometimes it was lower. For example: I entered 10.95 for the height, and it changed it to 11.037. What the heck is going on here??
Additionally how does it decide how what will allow before it changes to “No Artwork”? I wanted to score a line the entire width and height. If the object is larger, it changes to “No Artwork”. It would be nice if it would just score the line to the end, regardless if the object went outside the bounds. But I noticed as I was trying to find the max number, sometimes it would allow 10.95 and other times it would change to “No Artwork”. Is there some way to see what the max values are without having to enter in a bunch of numbers using trial and error?
