Loving the value of input from this group! Hoping there is a quick fix…
OK… went to cut/engrave earrings that filled a 6in x 6in acrylic (pattern ply, 3mm, masked).
what it did…
cut a half circle then wouldnt cut anything else but the head was going through the motions without laser
what I did…
cancelled print
pink light came on
shut off/unplug
checked forums and one mentioned mirror and white ribbon
mirror sparked a lightbulb because i had opened the top and took it out yesterday (had done cuts after that, which worked fine)
checked white ribbon… seems snug
first off-on and i was able to get the first 3 steps to be executed (2 cut steps and 1 engrave).
4th step was to be engraved but again, going through the motions without producing the engrave
another off-on, cleaned mirror and lenses, now laser is sporadic and weak on the engrave.
series of off-on-unplug attempts WITHOUT pink light coming back
tried changing settings for the engrave… still nothing… and the head seems to periodically go at a slower speed
Any suggestions?
Thanks to ALL!
