Has anyone engraved on a MagLite? If so what settings did you use? I can’t get the Glowforge to even put a mark on it.
Thank you
Which mag lite model? As I recall they were enameled metal but we can’t give you much advice without seeing the specific one.
Also a little more detail about what you’ve tried and how you set it up would go a long way.
What did you try? Is this anodized aluminum?
Could the problem you are having be a focus issue? Did you remove the honeycomb tray and elevate the light?
"Laser engraving will reveal a silvery white tone for excellent contrast. " yeah, that’s almost definitely anodized aluminum. Lotsa folks go with the Macbook PG settings
Thank you.
