I’m trying to design some wooden boxes, but I am having a hard time deciding which hinges to use. Unfortunately I’m in a bit of a time crunch and I don’t have time to make and test so many different ones.
(sorry, I’m still a beginner here)
Can anyone tell me about the durability of the laser cut hinges? Should I make the hinges out of acryllic for strength? or would it be better to just buy some metal ones and screw them on.
Welcome to the site!!
I think if you are in a time crunch, buy the hinges, and focus on making the boxes, this way you don’t get backed against the wall with time / learning curve,
IMHO
Jonathan
Are you using a box generator to make the boxes?
It would be helpful to know the thickness of the material you are using to make your boxes.
I am using 1/4" wood, and this box generator.
https://www.festi.info/boxes.py/
It does have two hinges, and I’m testing one of them as well as the one on the snowflake gift box designed by designvh619 if I can figure out the dimensions well enough.
That’s fair I guess. This is probably what I’ll end up doing at first, but I would like to try making my own hinges soon.
in time, you will make hinges that blow us away!!!
Jonathan
If you utilize the search function for hinged box, you will see some pretty ingenious solutions to the hinge problem. Here are two threads to consider: https://community.glowforge.com/t/gift-box-for-my-aries-sister/21295; Hinged Lid Box
Great, I’ll look through those. Thank you!
Yeah the leather hinge trick worked pretty well.
