Very new here. I ordered a file with three layers on Etsy. It is a map of the area I live in. When I import it into the Glowforge App, it appears on the left side (in little boxes), but nothing on the screen. Am I doing something wrong or completely missing a step?
Hopefully you can zoom out and it will be off side somewhere. You can then drag it onto the work area.
When I see that, I typically just click CTRL-A to select anything that may be there. Then I would click on the RULER icon at the bottom and click the top-left circle, to align by the top left corner. Then set that to X=0 and Y=0 and if anything was there, it is moved to that spot.
Great pointers from our other regulars here! If you write into support@glowforge.com with a screenshot, we may be offer more specific advice.
