I can’t seem to load the Hex Coaster set of 6 file from the design library to make the cut. Every time I load the file, nothing happen. Does anyone have the SVG file that can share?
thank you in advance.
At some point you likely deleted the contents of the file.
For Glowforge designs like this you can reset the design. Click the … on the top bar, and then click reset design.
Well, that was amazing!
it worked.
You’re a life saver.
Thank you Very much.
any chance i can get this in SVG file so i can make design within the hex?
GF doesn’t make the catalog files available for download, but if you go through the “first three prints” tutorial that was presented after you ran your setup, you’ll learn how to do this without needing the SVG file.
That makes allot of sense and it actually work.
thank you very much.
Thanks for the answers @jbmanning5 & @geek2nurse, that’s right. I’m going to close this thread.
