Here’s an idea for a Christmas present - I painted the two internal layers using normal water colors (may not work on all materials). You can size the design up or down as you please, as there are no tabs.
Note: the layers are overlapped in the svg, so you need to separate them/cut them at different times. It’s easier to note how they go together this way. And they ONLY go together one way, so make sure you’re aware of how to assemble them before you apply glue
