Home Assistant Home, partially made with a Glowforge
I needed to get better range for my bluetooth devices on my Home Assistant (raspberry pi) and decided to position it higher. It has just been sitting on the shelf next to the router for years. I just received a POE adapter and used Tinkercad for the 3D stuff and Cuttle for the laser cut files to make a permanent home for it.
I originally designed the 3D stand-offs to use magnets, but the friction fit was more than enough to hold the cover panel in place. The HD whiteboard engraves and cuts nicely.
The wasted circles from the front were perfect for offsetting for the hanger.
Related Links:
What an important practical cut.
Great practical cut, and so nice looking!
Looks great, but shame about the cable - can it be hidden?
Maybe run the cable up beside the molding to the right?
Nice design!
Love it. Well done
Great work. Like the design on the front.
@eflyguy and @davidgal2 Hiding cables are the least of my worries. :slight_smile:
I could make a new (white) cable if I had an rj-45 crimper, but haven’t need one in the last 10 years.
This is in the same room as the the glowforge. I don’t get a lot of visitors.
I get it. Just a thought. I have quite a few white ethernet cables, I think some flat cable ones as well. LMK if you’re interested and I’ll try and find one to send your way.
I am 3D printing a replacement clip for one of my cables now.
Great project, and nice design!
Great design!!
I was that way too. But the electrician didn’t put ends on the cables in the network box in the utility room - just raw Cat 6 cable ends. He did make the connections in the wall boxes throughout the house though.
I bought a new crimper and cable ends. The tech has changed a bunch since I last made cables. I bought pass-through connectors which are much easier to get the wire ends in correctly (order & length) before crimping and the crimper trims the ends off at the same time. Was way easier crimping cables than the last time I did it. Of course it was the last possible cable that needed a connector that was the one I needed for the connection I was trying to make :slight_smile: But now they’re all nicely fit with connectors and ready for me to keep setting up devices.
Very nice. I seem to have a problem with my actual internet having poor connections. (T-mobile home wifi now) Maybe I need a beautiful box to put it in. :wink:
