So I decided to share the svg’s for the Honeycomb necklace/earrings set.
I still need to work on kerf. if you zoom in closely you could see the round edge on the other side of the acrylic insert. Also, the insert could pretty much be a bit bigger for better fit but that’s for version No. 2
PG maple hardwood and two kinds of acrylic from inventables:
Transparent Dark Bronze Acrylic Sheet
Silver Mirrored Acrylic Sheet
I wonder if bamboo would be a better material (not as fragile).
I noticed yesterday when I made my Escutcheon out of PF Clear Acrylic that the KERF was not as noticeable as in the inventables stuff. Maybe something to consider.
And I think you may have done yourself a favor not going for a very tight fit… the stress will break hardwoods very easily along grain lines at that size. Guess how I learned that one?
No problem, the necklace is made out of two pieces of wood.
One with the hex design and cutouts and another solid piece of wood with the two chain holes. Then glue them together and add the acrylic inserts from the other file.
