how to save a glowforge file to my hard drive as an svg file
Assuming you are talking about catalog files, you canβt. You have the right to print it.
ok - what if I customize a file? I was just wanting to also cut some designs out of vinyl β thanks!
Any custom artwork that has been added can be exported, but not the original contents of the catalog file. Also note, vinyl is a no-no, it will destroy your machine.
This^^ Anything with Chlorine in it. The smoke combines with atmospheric moisture to become hydrochloric acid and the electronics are first to go.
OK Thank you
Yes I know β I have a cricut and silhouette and was anting to cut the image in vinyl from one of those machines. Thanks again for your help!
