Handy tip,… If you need to add mechanically accurate holes/cuts/engraves to a piece you’ve already cut, do the following: Cut just the outline of the piece in cardboard held in place by magnets, then place your piece in the cutout and run the job again with the outline set to ignore, and any additions turned on.
I can vouch for this technique. Works great!
Great tip!
