I had no idea I needed this metal cutting tool
… but I clearly do.
Is that a plasma cutter? :star_struck: I don’t need that tool as much as I need a good friend who owns that tool.
I wasn’t sure if it was plasma or a very precise laser. Either way it’s pretty awesome.
I think it’s a plasma based on how close the tip is to the work and it sounds like mine. But I’ve never heard a metal cutting laser so they may sound similar. My plasma is only a 2-axis CNC. That one is neat the way it is spinning the bar stock.
I thought it would be laser since it seems cleaner and narrower in kerf. It seems that the metal lasers are getting more common and cheaper , especially adding 4th and 5th axes. But I’m guessing and you have the experience with the plasma.
Cool. Put it next to the EDM cutter.
The computer drive is clearly the mind blower. Very custom in what it does though. Slap a CNC bit on it and you could make some awesome canes or balusters with vines and leaves climbing up but after all that you have just a pile of sticks :unamused:
I waffled back & forth on that. What tripped me to plasma was the closeness of the tip - I cut with only a 1/16" (.06") gap between the plasma tip & the material. My kerf with a pro (but not industrial big dollar) plasma cutter is .02" (with a cheap $800 plasma cutter it’s .05-.06"). That’s huge relative to a laser but when looking at parts being cutoff, it’s way smaller than you’d think based on saw kerfs. And I didn’t see a laser delivery mechanism for getting the laser to the head - might be in that handle with some kind of fiver but it could also be the plasma components too.
Just can’t be authoritative here :grinning:
I’m no expert… but I stayed at a holiday inn last night (not really).
I looked up some metal cutting lasers (like Kern), and they run the nozzle tip very close to the surface. But, that might be because I think they are injecting the gas (oxygen or nitrogen) through a nose cone along with the beam. They do make mention of economically-priced lenses for daily or weekly replacement. :grimacing:
What you (well, to be honest, what I) need is a water jet cutter. I don’t have enough use for Plasma. I’m not a metal fabricator and I’m not interested in being one. But I want to cut Carbon Fiber and it is painfully slow and messy as hell on my CNC. So I need a water jet cutter.
Yeah that would be awesome. The media is so expensive though…
That’s why I went plasma :slight_smile:
