how do i join these two images to cut as one? I tried group option and it does show it as one in illustrator but on the printer it still shows it as 2 cuts. 1. leaf, 2. apple. it would be a great help to me to cut it out as one image.
Thanks in advance!!
Problems and Support is a section of the forum for reporting problems with the Glowforge. Your problem is not with the Glowforge, it is with your understanding of Illustrator. I suspect you need to join the leaf to the apple stem, but I don’t use Illustrator. I suggest you review some Illustrator tutorials.
Select both objects.
Go to the Pathfinder Palette (find it in the Window menu).
Choose Unite.
Then turn it back into an object with no fill, but a stroke.
Thank you! Will try that now.
Any luck?
Worked perfect!
Making them the same color would also have worked. The GFUI groups operations by color.
I saw that too. Thank you!
